Home :: Axles & Parts :: 30mm :: Complete 30mm Axle Kit 6mm Keyway Gold Anodies Premium Billet Hubs
COMPLETE 30mm AXLE ASSEMBLY.  EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
1x 30mm Axle Shaft
1x 30mm Anodised Brake Hub
1x 30mm Anodised Sprocket Carrier/Hub
2x 30mm Low Friction Sealed Bearings
2x 30mm Anodised Self-aligning bearing carriers
2x 30mm Anodised Wheel Hubs
Axle Diameter: 30mm
Axle wall thickness: SOLID
Axle Length: 900mm
Keyway width: 6mm
Dimensions:
A = 7mm
B = 86mm
C = 170mm
D = 252mm
E = 565mm
F = 646mm
G = 700mm
H = 780mm
I = 814mm
J = 894mm
K = 900mm
30mm low friction free-spin bearings
Self-Aligning Bearing Flange/Holder/Cradle complete with 30mm Low Friction Race Bearing installed.
Holes are set 68mm apart from each other and 45mm from the centre.
Length: 90mm
Holes are set 78mm apart from each other and 67mm from the centre (Suit Standard 219 or 35 pitch Sprocket).
SKU AXC306G
Regular price: $570.25
Price with FREE DELIVERY: $349.00
$24.90
