Home :: Axles & Parts :: 25mm :: Complete MOWER-STYLE 25mm Axle Kit Less Shaft 6mm Keyway Sliver with Brackets & Wheel Adaptors (PILLOW BLOCK STYLE, ORANGE WHEEL HUBS AND BRAKE HUB)
COMPLETE 25mm AXLE ASSEMBLY Less Shaft.  EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!  This is a dream price!
1x 25m Anodised Brake Hub ($80)
1x Drilled Brake Disc ($120)
1x 25mm Anodised Sprocket Carrier/Hub ($55)
2x 25mm Low Friction Sealed Bearings ($50)
2x 25mm Cast Self-aligning bearing carriers ($80)
2x 25mm Anodised Wheel Hubs ($85)
SUITS AXLETYPE
Suits Axle Diameter: 25mm
Keyway width: 6mm
25mm low friction free-spin bearings
Self-Aligning Bearing Flange/Holder/Cradle complete with 25mm Low Friction Race Bearing installed.
Holes are set 65mm apart from each other and 38mm from the centre.
6mm Keyway
6mm Keyway
SKU AXSLC25
Regular price: $686.63
Price with FREE DELIVERY: $359.00
