Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Clutch and Throttle Cable Mount Kit suits CPR LIFAN 6.5hp Engines
BRAND NEW Clutch & Throttle Cable mount kit.
Complete kit includes everything you need to mount a clutch and throttle cable including installation guide.
Are you having struggling to figure out how to attach a throttle cable, or a clutch?  Throttle cables need to be mounted properly to avoid full throttle sticking conditions which are at the very least - scary.  And downright dangerous.  Well worry no more because our kit takes all the hassle out of mounting clutches and throttle cables.   Using our specialist cable retainer and swivel you'll have a safe reliable setup without the headaches, plus all the hardware to mount the clutch too.
Kit includes:
- Swivel terminator for throttle cable - attaches to lever (drill hole, insert swivel mount and retain with circlip)
- Spacer washer to correctly position the clutch
- Grub screw for cutches with grub screw setting point
- Retainer bolt and washer (for end of crankshaft) suits honda-clone engines
- Improved throttle return spring to ensure throttle closes off-pedal
- Throttle cable seat to ensure smooth operation of throttle cable, and correct positioning
- Installation instructions (CLICK HERE TO VIEW THE INSTALLATION INSTRUCTIONS)
ClutchChangingGuide
TCCGuide
SKU CTMKC1
Regular price: $38.35
Price with FREE DELIVERY: $29.95
Clutch Dry SR Series 35 Pitch 12 Tooth 19mm (3/4inch) bore
Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore
Clutch Dry SR Series 35 Pitch 12 Tooth 19mm (3/4inch) bore Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore
$59.90
$49.95
Clutch Dry SR Series 420 Pitch 10 Tooth (19mm - 3/4inch bore)
Go Kart SR 3/4" Clutch, Chain and Sprocket BUNDLE 420/40/41 Pitch BRAND NEW
Clutch Dry SR Series 420 Pitch 10 Tooth (19mm - 3/4inch bore) Go Kart SR 3/4" Clutch, Chain and Sprocket BUNDLE 420/40/41 Pitch BRAND NEW
$69.90
$124.90
