Home :: Clutches :: Clutch Shoe Pair LIGHTWEIGHT CPR GT-RACE Series
Lightweight shoes to suit GT-RACE clutch range (also compatible with NORAM GE clutches)
ONE PAIR.
(Lightweight shoe pair only - picture of assembled unit for representation of final assembly)
Lightweight shoes offer a slower engagement at higher rpm.  Ideal for use with mild to wild engine tunes with high lift ad duration cams producing torque high in the RPM range.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CSGTL1
