Home :: Clutches :: Clutch Spring SR Up-rated spring (2200rpm engagement speed) - Suits all CPR SR Clutches
Genuine CPR SR Clutch Up-Rated Spring
This is a replacement spring designed to increase the stall from 1900rpm to approximately 2200rpm for racing purposes.  This allows more torque to be transferred to the wheels for a faster exit in tight corners.
This part can also be used to breathe new life into a failed clutch where it has been overheated.
Fits all Genuine CPR SR clutches - 5/8", 3/4" and 1".
ClutchChangingGuide
TCCGuide
SKU CSPRHD
