Home :: Clutches :: Clutch Noram TITAN 25.4mm (1") bore (Green Springs) HIGH PERFORMANCE Race Clutch up to 20hp
Noram TITAN Clutch suit big block 4-stroke with 1" (25.4mm) Bores.
BASE MODEL CLUTCH WITHOUT SPROCKET
Supplied with GREEN springs for approx 3600RPM engagement.
Length of inner shaft ~45mm - requires approx 40mm long shaft.
Approx. diameter of body of clutch = 117mm
SKU CNTI25
$32.95
$26.95
