Home :: Clutches :: Clutch Noram Stinger 35 Pitch 12 Tooth 19mm (3/4") bore HIGH PERFORMANCE Race Clutch
35 Pitch Noram Stinger Clutch suit 4-stroke.
Includes 12T drive sprocket.
The Stinger Racing Go Kart Clutch is a powerful 3-shoe kart racing clutch. It features a one-piece drum with interchangeable drive sprockets. It also features Premier’s exclusive shoe/spring/hub “cartridge” which allows for quick and easy set-up changes.
A super-reliable clutch for high horsepower applications.  Successful on dirt circuits as well.  A great alternative to disc-type clutches where higher levels of reliability are required but with similar levels of convenience - simply keep a spare cartridge on hand and fit with a different spring combination if testing for quick stall speed swaps at the track.
SKU CNSY1
