Home :: Clutches :: Clutch Noram STAR 25.4mm (1") bore (RED Springs) HIGH PERFORMANCE Race Clutch (BASE CLUTCH, NO SPROCKET OR DRUM) - OFFICE USE ONLY
****BASE CLUTCH WITHOUT DRUM/SPROCKET****
Noram STAR Clutch suit big block 4-stroke with 1" (25.4mm) Bores.
Designed to operate reliably up to approximately 20hp, but we've seen these on engines producing a lot more HP.  Ideal reliable option for Racing Mowers.
Supplied with RED springs for approx 2400RPM engagement.
Includes key.
Length of inner shaft (shoe section only) ~30mm - requires approx 30mm long shaft to fit.  Length of shaft utliised when drum fitted = ~58mm.  Ideal length of shaft = 58mm.
Approx. diameter of body of clutch = 115mm
SKU CNS25
