NEW
Hilliard inferno Blaze racing clutch. Uses our CPR GT Sprockets for easy access to all sizes #34 and 219P.
Kit includes sprocket (as per title) - choose the sprocket your would like in the configuration menu.
(PLEASE NOTE, BASE CONFIGURATION INCLUDES 13T #35 SPROCKET. SOME SPROCKET SIZES ARE PRICED DIFFERENTLY - CHANGING YOUR SPROCKET SIZE MAY AFFECT THE PRICING OF THE KIT) Kit includes one set of springs (choose in the configurator).
Kit includes two sets of weights.
The Inferno Blaze clutch is the lightest clutch in the Inferno product line. The Blaze clutch is a good choice for JR classes, small tracks, or when running indoor racing where you want less rotating inertia in the clutch. The patented shoe design can be placed in a leading, trailing, or combination of leading and trailing orientation. The shoes also have three holes that allow the racer to add or remove weights to each shoe. Light and Heavy weights are available for optimal tuning. Quick changes with any combination of weights, springs, and shoe orientation gives the racer the ability to keep the clutch tuned to the track's current condition or to the different tracks that you race.
Installation instructions are included in the box, as well as can be downloaded here or viewed on our site here.
Because our clutch also has the Bully conversion to suit our Noram/Bully sprockets, you'll also need to use the following instruction guide alongside the standard Hilliard ones:
Engagement spring options (Choose options in the configuration wizard)
4600rpm - 4x Black
4400rpm - 4x Black with 1 weight per shoe
4300rpm - 4x Black with 2 weights per shoe
4000rpm - 4x Black with 3 weights per shoe
3900rpm - 2x Black, 2x White
3800rpm - 2x Black, 2x White with 1 weight per shoe
3700rpm - 2x Black, 2x White with 2 weights per shoe
3400rpm - 2x Black, 2x White with 3 weights per shoe
3700rpm - 2x Black, 2x Yellow
3600rpm - 2x Black, 2x Yellow with 1 weight per shoe
3500rpm - 2x Black, 2x Yellow with 2 weights per shoe 3300rpm - 2x Black, 2x Yellow with 3 weights per shoe 3300rpm - 4x White
3200rpm - 4x White with 1 weight per shoe
3100rpm - 4x White with 2 weights per shoe 3000rpm - 4x White with 3 weights per shoe 3000rpm - 2x White, 2x Yellow
2900rpm - 2x White, 2x Yellow with 1 weight per shoe 2800rpm - 2x White, 2x Yellow with 2 weights per shoe 2700rpm - 2x White, 2x Yellow with 3 weights per shoe 2750rpm - 4x Yellow
2650rpm - 4x Yellow with 1 weight per shoe
2550rpm - 4x Yellow with 2 weights per shoe 2500rpm - 4x Yellow with 3 weights per shoe 2550rpm - 2x Yellow, 2x Orange
2450rpm - 2x Yellow, 2x Orange with 1 weight per shoe 2400rpm - 2x Yellow, 2x Orange with 2 weights per shoe 2300rpm - 2x Yellow, 2x Orange with 3 weights per shoe 2350rpm - 4x Orange
2250rpm - 4x Orange with 1 weight per shoe
2100rpm - 4x Orange with 2 weights per shoe 2000rpm - 4x Orange with 3 weights per shoe New.
| SKU | CHIB34C | |
| Base product price: |
$379.00
including GST 10% |
