Home :: Clutches :: Competition Hilliard Inferno and Bully Range :: Clutch Hilliard Inferno Fury 35 Pitch 19mm (3/4") bore with #35 or 219P sprocket
NEW
Hilliard inferno fury racing clutch.  Uses our CPR GT Sprockets for easy access to all sizes #34 and 219P.
Kit includes sprocket (as per title) - choose the sprocket your would like in the configuration menu.
(PLEASE NOTE, BASE CONFIGURATION INCLUDES 13T #35 SPROCKET.  SOME SPROCKET SIZES ARE PRICED DIFFERENTLY - CHANGING YOUR SPROCKET SIZE MAY AFFECT THE PRICING OF THE KIT)
The Inferno Fury racing clutch is engineered to last longer and provide more consistent torque than conventional drum style racing clutches. The clutch shoes are thermo-dynamically designed to minimize heat transfer to the springs. This allows the clutch to handle the heat generated from the clutch without damage to the springs. The racing drum is stamped and machined to a tight tolerance on the inside diameter to ensure even contact between the shoe surface and the drum for consistent engagement and torque. The Inferno racing clutch series can be adjusted without removing the chain. Quick change springs allow less time making adjustments in the pits and more time on the track. Designed for dirt or asphalt, oval, sprint or road courses, Inferno clutches are track tested and proven winners. Inferno clutches are shipping with needle bearing style designs but are still available in the oil impregnated bushing for certain applications. The new needle bearing sprockets and Inferno drum interface provide the best support of the drum when compared to other sprocket interfaces. The use the Inferno style racing sprockets will provide the best consistency and performance out of the clutch.
Installation instructions are included in the box, as well as can be downloaded here or viewed on our site here.
Because our clutch also has the Bully conversion to suit our Noram/Bully sprockets, you'll also need to use the following instruction guide alongside the standard Hilliard ones:
Engagement spring options (Choose options in the configuration wizard)
3400rpm - 4x Black
2900rpm - 2x Black, 2x White
2800rpm - 2x Black, 2x Yellow
2750rpm - 2x Black, 2x Orange
2400rpm - 4x White
2150rpm - 4x Yellow
1700rpm - 4x Orange
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CHIF34C
Base product price: $329.00
