Home :: Clutches :: 18 Tooth #35 Drive sprocket suit CLC3518 Clutch Dry 35 Pitch
18Tooth sprocket to suit 35 Pitch Dry Clutch
Suits CPR SR CLUTCH with standard 19mm Drive Shaft.
ID of bush = 19.05mm 3/4inch
*NOTE this only fits CPR SR clutches with removable 18T sprockets - if you have a circlip on the underside of the drum holding the sprocket in, then you can remove that to replace the sprocket.
SKU SPR35F18
