Home :: Clutches :: Clutch Drum Only Hilliard to Cheetah or GE sprocket (Converts Hilliard Clutch to CPR Sprockets) 19.05mm bore
NEW
DRUM
 ONLY
Hilliard Inferno clutch drum to suit our CPR Sprockets (Same as Noram Cheetah / GE Ultimate) so you can access our full range of 219, #35, and 420P sprockets for your Hilliard clutch!
*NOTE: Will not work with Hilliard FIRE clutch.  THIS IS NOT THE FULL CONVERSION KIT, this is just the replacement drum - if you do not already have this style of sprocket on your Hilliard Clutch you will need the full converstion kit ( CHCN34 )
GTClutchChoiceGuide
SKU CHDRN1
