Home :: Clutches :: Clutch DRUM AND SPROCKET ONLY suits Noram STAR 25.4mm (1") bore (SLEEVE BEARING STYLE) 13T #35 Pitch
NOTE: THIS 13T MODEL HAS A SLEEVE BEARING (not roller bearing as pictured on the larger teeth number options)
SKU CNSD1335
