Home :: Clutches :: Clutch Conversion Hilliard to Cheetah or GE sprocket (Converts Hilliard Clutch to CPR Sprockets) 19.05mm bore
NEW
Converts standard Hilliard Inferno clutch drums to suit our CPR Sprockets (Same as Noram Cheetah / GE Ultimate) so you can access our full range of 219, #35, and 420P sprockets for your Hilliard clutch!
*NOTE: Will not work with Hilliard FIRE clutch.
GTClutchChoiceGuide
SKU CHCN34
