Home :: Clutches :: Clutch CPR GT-RACE Series 35 Pitch 16 Tooth 19mm (3/4inch) bore)
CPR's new GT-RACE series selects our performance components to suit competitive racing go-karts for track competition purposes. Uncompromising quality at the most affordable price
Includes 16T drive sprocket.
Supplied with RED springs and Heavy Shoes for approx 2000RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3516B
Price with FREE DELIVERY: $179.00
$32.95
$26.95
19mm Crankshaft Clutch Installation Kit (suit GX200 / GX160) (Special Washer, Bolt, and Spacer)
$9.95
