Home :: Clutches :: Clutch CPR GT-RACE Series 35 Pitch 15 Tooth 19mm (3/4inch) bore) (BASE UNIT)
CPR's new GT-RACE series selects our performance components to suit competitive racing go-karts for track competition purposes. Uncompromising quality at the most affordable p
Includes 15T drive sprocket.
Supplied with RED springs and Heavy Shoes for approx 2000RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3515B
Price with FREE DELIVERY: $179.00
$32.95
$26.95
19mm Crankshaft Clutch Installation Kit (suit GX200 / GX160) (Special Washer, Bolt, and Spacer)
$9.95
