Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 35 Pitch 12 Tooth 19mm (3/4inch) bore (BASE UNIT) (SCOUTS)
Includes 12T drive sprocket.
Supplied with RED springs and Heavy Shoes for approx 2000RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3512B_SCOUTS
