Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 35 Pitch 12 Tooth 19mm (3/4inch) bore (BASE UNIT)
Includes 12T drive sprocket.
Supplied with RED springs and Heavy Shoes for approx 2000RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3512B
19mm Crankshaft Clutch Installation Fit Mount Kit (suit GX200 / GX160) (Special Washer, Bolt, and Spacer)
$9.95
