Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 35 Pitch 12 Tooth 19mm (3/4") bore with Orange Springs (3100rpm)
Includes 12T drive sprocket.
Supplied with ORANGE springs for approx 3100RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3512_O
Regular price: $203.59
Price with FREE DELIVERY: $189.00
$9.95
