Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 35 Pitch 12 Tooth 19mm (3/4") bore with HIGH RPM RED Springs (3530rpm)
Includes 12T drive sprocket.
Supplied with HIGH RPM RED springs for approx 3530RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3512_HR
Regular price: $203.59
Price with FREE DELIVERY: $189.00
$9.95
