Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 35 Pitch 12 Tooth 19mm (3/4") bore with Green Springs (2975rpm)
Includes 12T drive sprocket.
Supplied with GREEN springs for approx 2975RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3512_G
Regular price: $203.59
Price with FREE DELIVERY: $189.00
$9.95
