Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 35 Pitch 12 Tooth 19mm (3/4") bore with Red Springs (2000rpm)
Includes 12T drive sprocket.
Supplied with RED springs for approx 2000RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT3512_R
Regular price: $162.73
$9.95
