Home :: Clutches :: Race GT Range :: Clutch CPR GT-RACE Series 219 Pitch 20 Tooth 19mm (3/4inch) bore (BASE UNIT)
219 Pitch RACE CPR GT Clutch suit 4-stroke and Torini Clubmaxx for 4SS Competition.
Includes 20T drive sprocket.
Supplied with RED springs and Heavy Shoes for approx 2000RPM engagement.
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGT21920
19mm Crankshaft Clutch Installation Fit Mount Kit (suit GX200 / GX160) (Special Washer, Bolt, and Spacer)
$9.95
