Home :: Clutches :: Clutch BASE Noram Torini Series 19mm (3/4inch) bore (Suits Torini Clubmaxx 4SS Engine) GE Ultimate
Homologated Torini Clubmaxx Noram GE Ultimate Clutch
BASE CLUTCH - NO SPROCKET INCLUDED
Supplied with RED springs and Light Shoes for approx 2200RPM engagement.
SKU CLTGEL
