Home :: Sprockets & Chains :: 35 Pitch Chains :: Chain Tensioner (on-board) for #35 420 428 Pitch Chains
Chain Tensioner to suit #35 420 or 428P Chains.
If your chain is falling off all the time, perhaps it's a little long?  A chain tensioner will allow you to keep tension on longer chain lengths, ensuring they stay attached to the vehicle and providing tension as stretching occurs.
Complete unit.  Designed to be fitted to a chassis rail to dynamically tension chains.  Fantastic for use with our Jackshaft kits, or if running a really long chain.
Mounting hole 15mm DIA, or you can drill a new hole to mount.
Length of mounting bracket 88mm
diameter of roller 24mm (inside surface diameter)
SKU CTNC01
