Home :: Fuel Tanks & Parts :: Line & Filters :: Catch Can - Engine oil catch can small Updated Version
Brand New Catch Can - Engine oil catch can small
Why use an oil catch can?
Rather than venting directly to the atmosphere, the waste gasses trapped in your rocker cover can be vented back into your intake system via the catch can which traps all the oily residues and oil components, leaving clean waste air to be recycled.
Using a catch can will allow you to visibly inspect the amount of oil being vented.  Great for heavily worked engines with large clearances and blow-by.
Our catch can is easy to install, easy to locate and mount, and easy to empty.
Dimensions:  43mm Diameter, 75mm Long/High.
SKU EOCCS2
