Home :: Fuel Tanks & Parts :: Line & Filters :: Catch Can - Engine oil catch can large (WITH BLUE LINE)
*PLEASE NOTE, DETAILED IMAGES SHOW RED LINE, BUT BLUE LINE IS INCLUDED WITH THIS MODEL, NOT RED
Brand New Catch Can - Engine oil catch can large
Why use an oil catch can?
Rather than venting directly to the atmosphere, the waste gasses trapped in your rocker cover can be vented back into your intake system via the catch can which traps all the oily residues and oil components, leaving clean waste air to be recycled.
Using a catch can will allow you to visibly inspect the amount of oil being vented.  Great for heavily worked engines with large clearances and blow-by.
Our catch can is easy to install, easy to locate and mount, and easy to empty.
Dimensions:  60mm Diameter, 160mm Long/High.
SKU EOCCLN
