Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Carby to Engine Connecting Rubber suit Dellorto VHSB Rotax 125 Max
Connecting Rubber for Rotax Carburettor.
Suits Rotax 125 / Rotax Max 125 with VHSB Carby
This part is the wearing component between the carb and engine block.  Failure of this component is the main cause of leaning out and causes piston seizure.  If you are experiencing piston seizure with no known cause, check this part and replace it.
SKU CCRD01
