Home :: Engines, Carbs & Parts :: Engines :: Camshaft for Predator 212 old-style (non-hemi) Stage 2
Super High Torque, Use for small to medium tracks. 4500 to 7500 rpm range, 11 to 1 or higher compression ratio & 26+ lb Springs required. DESIGNED TO GET YOU OFF THE CORNERS.
Intake:
Open 52.4 BTDC
CLose 89.4 ABDC
Lift 0.265
C/L 108 ATDC
Valve Lash .003
Exhaust:
Open 86.9 BBDC
CLose 51.5 ATDC
Lift 0.265
C/L 108 BTDC
Valve Lash .003
Suits Camshaft for Predator 212 NON-HEMI Engines (Old-style non-Hemi head engines have pressed steel (stamped) valve cover).
Sidecover Journal size of this cam is approx 14.17mm
SKU CMA265X
