Home :: Steering Components :: Stub Axles & Spindles :: Camber Castor Adjuster Kit Pair Suit 8mm Pin GENUINE CPR (GT-LOCK 16 Hole)
NEW! Camber Adjusters for 8mm King Pins!
We know these are super-difficult to get, and we've answered your call! New and in-stock ready to ship are our Genuine CPR GT-LOCK Camber/Castor adjusters with optional locking pins (screws).
GT-LOCK
With 16 pre-drilled holes you can lock our GT-LOCK CPR Camber/Castor adjusters in position on most frames (including genuine CPR frames from Mid 2018+)
Hole PCD is 32.5mm x 4mm
FIX OUT OF ALIGNMENT STEERING!
Adjust Camber and Castor on your kart - even if your kart didn't come with adjustment from factory!
FITS MOST RACE KARTS WITH 8MM KINGPINS
Designed for the most popular configuration, our kits suit race karts with 8mm KingPins and up to 14mm holes in the C clamp (if yours has 8mm holes, simply re-drill to 14mm)
EASY TO ADJUST
All you need to do to adjust your camber and caster is to remove the lockign pins, slighitly loosen your king pin and rotate the adjusters, then re-tighten , re-install the locking pins and race!
IN STOCK READY TO SHIP
If you want to get your hands on one today, we've got them in stock and ready to ship!
BRAND NEW Pair of Genuine CPR GT-LOCK Camber Adjustment locks designed for our CHBC01 chassis.
To suit frames with 14mm top hole and 8mm King Pins.
14mm OD, 8mm ID Offset kingpin hole
See related items for the locking pins (screws) - one or two per camber adjuster may be used.  You may need to drill and tap holes to suit if you wish to use those without existing factory threads.
SKU CMBC02
