Home :: Brakes & Parts :: Cable :: Cable to suit Cable Brake Kit (GT Cable)
BRAND NEW Cable - suits CPR Cable Brake Kit
CPR GT MODEL
Length = 160cm
Sheath Length = 90cm
Inner cable diameter = 2.5mm
Outer Sheath Diameter = 7mm
Ball end diameter = 7mm
GTBrakeGuide
SKU BKCCC2
$79.00
$34.95
$9.95
$7.95
$16.95
