Home :: Brakes & Parts :: Cable :: Cable Brake Kit GT-RACE (Mechanical Calliper AND Cable)
WHY SHOULD YOU BUY OUR CPR BRAKE SYSTEMS?
PADS AVAILABLE IN STOCK - We've kept the same pad design for over 15 years, ensuring you can buy pads for your CPR system for many more years or decades to come!
SPARE PARST IN STOCK - We always carry parts to service our CPR brand items, in fact you can still buy parts to suit our oldest models over 15 years old!
PERFORMANCE - We source reliable and high performance parts in order to give you the best experience - so you tell your friends.
BRAND NEW Mechanical Brake Calliper and Cable KIT
NEW MODEL
I
NCLUDES BRAKE 1.6m CABLE
CPR GT-RACE Cable Brake Calliper.
The CPR Cable Brake assembly will work on larger discs (like 12 or 18mm width discs) effectively.
Also works with thinner discs - just remove the supplied spacers!
Compatible with discs from 190mm up to 210mm in diameter.
Suits up to 12mm disc in standard form.
*Suit thinner disc if optional spacers/washers are removed.
*Suit up to 18mm disc if fitted with optional spacers/washers (not supplied - SEE RELATED PRODUCTS to purchase these from us - 1 packs requred)
^Mountings holes suit 61mm brackets,
A= 61mm^, B=Up To 18mm*, C=N/A
WHY ARE THEY SO CHEAP? Well we buy direct from the manufacturer in bulk, not via a local distributor and that means you SAVE HEAPS! If you're looking for an advantage on the track and are not interested in paying huge prices then try our GT-RACE range and join the growing community of affordably competitive racers today!.
GTBrakeGuide
SKU BKCC02
Regular price: $218.00
Price with FREE DELIVERY: $119.90
$79.00
$34.95
$9.95
$7.95
Brake Calliper 6mm Spacer Shim Set to suit BKHC04 and BKCC02 (6pcs x1mm spacers) Bracket for Brake Calliper suit CPR BKCH04 & BKCC02 & BKHC02 Brake Kits
$16.95
$24.90
