Home :: Brakes & Parts :: Cable :: Cable Brake Kit GT-RACE (Calliper Only)
BRAND NEW Cable Brake Calliper
NEW MODEL
CPR GT-RACE Cable Brake Calliper.
The CPR Cable Brake assembly will work on larger discs (like 12 or 18mm width discs) effectively.
Suits up to 12mm disc in standard form using the supplied bracket and bolts.
*Suit thinner disc if optional spacers/washers are removed.
*Suit up to 18mm disc if fitted with optional spacers/washers (not supplied - SEE RELATED PRODUCTS to purchase these from us - 1 packs requred)
Also works with thinner discs - just remove the supplied spacers! Compatible with discs from 190mm up to 210mm in diameter.
^Mountings holes suit 61mm brackets,
A= 61mm^, B=Up To 18mm*, C=N/A
GTBrakeGuide
SKU BKCCM2
$79.00
$34.95
$9.95
$7.95
$16.95
