Home :: CPR RS-32 Bare Chassis Frame - suits 2 and 4 stroke karts (MODULE 1 OF BTC-DIY KIT)
THIS IS THE NEW MODEL AND SUITS PSCC1 NEW-STYLE (CRG NA2) PLASTICS SET
NOTE: This \chassis does not included welded engine mount - you will require an additional mount to fit an engine.
Brand New Bare Chassis.
Our new CPR Chassis has been re-developed using a chrome-moly material for extra rigidity and strength.
Now includes all parts required to complete the chassis including:
- Tube Chassis
- Floor Pan
- Front Crash Bar / Nose Cone retainer Bar
- Rear Crash bar mounts
- Side Pod Bars (Suit New-Style Plastics Set)
- Nassau Panel Support bars
- Fitting kit (Includes Nose Cone clamp, all bolts to connect all bars and floorpan as well as bolts to connect plastics)
32/32mm Chassis Rails.
Senior Chassis - 1050mm wheelbase, 640mm Outer Chassis Rail to Outer Chassis Rail.
Includes engine mount (welded) but can be cut and removed to fit alternative mount..
Direct bolt-on fit mount for our LIFAN 6.5HP Engines.
Suits most CPR parts - direct bolt-on fit.
 Bare Chassis - Brand New
SKU CHBC01
Regular price: $10241.57
Price with FREE DELIVERY: $9999.00
