Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Budget Aftermarket Mikuni-Style Slide Carburettor Carb Carby 22mm suits Honda GX200 & Clone CLEARANCE ITEM
CLEARANCE.
Aftermarket Mikuni-Style Slide Carb 22mm.  Compatible with Mikuni parts such as main jets.
Cast aluminium body.
Extremely effective performance upgrade for GX200 & Clone style engines.  Does require inlet manifold and venturi adapter sold separately.
Includes 95 Main jet (uses 5mm x 0.8mm style main jets)
and 38 Pilot Jet (uses Keihnen style with bevelled end pilot jet)
Stud spacing is 48mm centre to centre, 6mm studs
Suits 39.5mm ID Adapter for air filter (available separately - see 'related items' below)
Requires Mikuni to GX200 manifold (available separately - see 'related items' below)
29%
SKU CMSBNC
