| 15.875 5/8inch to 19.05mm 3/4inch Crankshaft Converter Sleeve Adapter Adaptor Kit | 19.05mm 3/4inch to 25.4mm 1inch Crankshaft Converter Sleeve Adapter daptor AKit |
SKU: ECSC58
SKU: ECSC34
Price with FREE DELIVERY: $29.95
including GST
10%
including GST
10%
| 19mm Crankshaft Clutch Installation Fit Mount Kit (suit GX200 / GX160) (Special Washer, Bolt, and Spacer) | 19mm Crankshaft Clutch Spacer (suit GX200) |
SKU: CLIKC1
SKU: SPCR34
Price with FREE DELIVERY: $9.95
including GST
10%
Price with FREE DELIVERY: $4.95
including GST
10%
| 25.4mm 1-inch Crankshaft Clutch Mount Installation Kit (suit GX390) (Special Washer, Bolt, and Spacer) | 25.4mm 1-inch Crankshaft Clutch Spacer (suit GX240 GX270 GX340 GX390 PRED440 |
SKU: CLIKC3
SKU: SPCR254
Price with FREE DELIVERY: $17.95
including GST
10%
including GST
10%
| Chain Tensioner (on-board) for #35 420 428 Pitch Chains | Clutch and Throttle Cable Mount Kit suits CPR LIFAN 6.5hp Engines |
SKU: CTNC01
SKU: CTMKC1
Price with FREE DELIVERY: $29.90
including GST
10%
including GST
10%
| Clutch DRUM ONLY CPR SR 219 Pitch 16 Tooth 19.05mm 3/4inch Bore | Clutch Dry CPR SR 219 Pitch 16 Tooth 20mm bore |
SKU: CLC21916
SKU: CLC21916_20
Price with FREE DELIVERY: $99.90
including GST
10%
Price with FREE DELIVERY: $104.90
including GST
10%
| Clutch Dry CPR SR 219 Pitch 17 Tooth 15.875mm (5/8inch) bore | Clutch Dry CPR SR 219 Pitch 17 Tooth 19mm (3/4inch) bore |
SKU: CLC21917_58
SKU: CLC21917
Price with FREE DELIVERY: $74.90
including GST
10%
including GST
10%
| Clutch Dry CPR SR 219 Pitch 17 Tooth 20mm bore | Clutch Dry CPR SR 35 Pitch 12 Tooth (5/8inch) bore |
SKU: CLC21917_20
SKU: CLC3512_58
including GST
10%
Price with FREE DELIVERY: $69.90
including GST
10%
| Clutch Dry CPR SR 35 Pitch 12 Tooth 20mm Bore | Clutch Dry CPR SR 35 Pitch 13 Tooth (5/8inch) bore |
SKU: CLC3512_20
SKU: CLC3513_58
including GST
10%
including GST
10%
| Clutch Dry CPR SR 35 Pitch 13 Tooth 20mm bore | Clutch Dry CPR SR 35 Pitch 18 Tooth (5/8inch) bore |
SKU: CLC3513_20
SKU: CLC3518_58
including GST
10%
Price with FREE DELIVERY: $59.90
including GST
10%
| Clutch Dry CPR SR 35 Pitch 18 Tooth 20mm Bore | Clutch Dry SR Series 35 Pitch 12 Tooth 19mm (3/4inch) bore |
SKU: CLC3518_20
SKU: CLC3512
including GST
10%
including GST
10%
| Clutch Dry SR Series 35 Pitch 13 Tooth 19mm (3/4inch) bore | Clutch Dry SR Series 35 Pitch 15Tooth 25.4mm (1inch) bore |
SKU: CLC3513
SKU: CLC3515
including GST
10%
Price with FREE DELIVERY: $64.90
including GST
10%
| Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore | Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore WITH ROLLER BEARING DRUM |
SKU: CLC3518
SKU: CLC3518_RB
Price with FREE DELIVERY: $49.95
including GST
10%
Price with FREE DELIVERY: $64.95
including GST
10%
| Clutch Dry SR Series 420 Pitch 10 Tooth (15.875mm 5/8inch bore) | Clutch Dry SR Series 420 Pitch 10 Tooth (19mm - 3/4inch bore) |
SKU: CLC42010_58
SKU: CLC42010
including GST
10%
including GST
10%
| Clutch Dry SR Series 420 Pitch 10 Tooth 20mm Bore | Clutch Dry SR Series 420 Pitch 14 Tooth (25.4mm - 1inch bore) |
SKU: CLC42010_20
SKU: CLC42014
including GST
10%
including GST
10%
| Clutch Dry SR Series 428 Pitch 10 Tooth (15.875mm 5/8inch bore) | Clutch Dry SR Series 428 Pitch 10 Tooth (19mm - 3/4inch bore) |
SKU: CLC42810_58
SKU: CLC42810
Price with FREE DELIVERY: $79.90
including GST
10%
including GST
10%
