Home :: Chassis Parts :: Crash bars and linkages :: Brake linkage rod connector from Master to Pedal
Brake rod/linkage to connect pedals to brake master units.
Adjustable length - 440mm down to 60mm (thread continues entire length of rod)
Suitable for senior sized karts (or junior karts - can be modified easily)
The pictures show the connection to the master and to the pedal.
THE ROD DOES NOT COME WITH PINS OR BRAKE SYSTEM/PEDAL/SPRINGS ETC IN THE INSTALLATION PICTURES
If you need pins, they can be found in the "Related" section below.
Brand New.
SKU BRDC01
Hydraulic Brake Kit including Master & Calliper
Brake Rod Retainer Pin & Split Pin suit CPR Brake Rod
Hydraulic Brake Kit including Master & Calliper Brake Rod Retainer Pin & Split Pin suit CPR Brake Rod
$119.90
$1.95
