Home :: Brakes & Parts :: Accessories & Parts :: Brake Calliper 6mm Spacer Shim Set to suit BKHC04 and BKCC02 (6pcs x1mm spacers)
Brand new Spacer set 6pcs
Each piece approx 2mm thickness.  2 Pieces are needed per 2mm increase in disc thickness.
Each pair will increase the distance between the callipers by approx 2mm, allowing for an increase in disc thickness of approx 2mm.
If you are using the BKHC04 on a 12mm disc, one pack of 6 spacers is required.
Compatible with CPR BKHC04 Race Hydraulic Brake and BKCC02 Mechanical Cable Brake systems.
SKU BHS046
Hydraulic Brake Kit (Pro Race Type) including Master & Calliper
$279.90
