Home :: Brakes & Parts :: Accessories & Parts :: Brake Line Hydraulic 6mmOD 4mmID per Metre
Brand new nylon hydraulic brake line.  6mm Outer, 4mm Inner.
To make up your line, for standard systems you'll need one I connector, on T connector, and two L connectors.  Connectors come complete with all olives required.
If you buy each of the suggested items, you'll have all you need to create a brand new line to fit your kart.
Brand new Cup seals for reconditioning brake callipers / master cylinders.
Price is per individual seal. Buy just one or the amount you need.
Item title describes size.
You can check your size by looking at the inside of the cup once you remove your current ones.
" target="_blank">
SKU BKLH01
Hydraulic Brake Kit including Master & Calliper
$119.90
