Home :: Axles & Parts :: 40mm :: Brake Disc 4mm suits 3 bolt AXCC408 Brake Hub (Standard Wheel Hub PCD)
Brake Disc to suit 3-bolt carrier/hub (same pcd as wheel hubs)
This is an inexpensive way to add a brake disc to a race kart.  Simply use a wheel hub of the correct size and bolt this disc to it!  Easy as!
High Quality part.
No Hub or Bolts included (pictured for reference only)
Brake Disc Thickness @ 3.5mm
55%
SKU BDC4
