Brand new Spacer Shim
Each piece approx 1.6mm thickness. 4 Pieces are needed to increase disc thickness to 12mm from the stock 6mm, or 8 Pieces to go from 6mm to 18mm.
Each pair will increase the distance between the callipers by approx 1.6mm, allowing for an increase in disc thickness of approx 1.6mm.
If you are using the BKCS01 on a 12mm disc, 4 spacers are required.
Compatible with CPR BKHC04 Race Hydraulic Brake systems.
New. Click the condition meter to learn more about used items.
