Go Kart Brake Bleeding Tool...
Drivers
DRIVER PROFILES AROLMRA
Tracks
CPR KARTBEAT NEWS
Subscribe to our UPDATES
Bank & Paypal Details
Shipping & Trading Hours
Contact Details
About Us
Condition Meter
Refunds & Returns
Privacy Policy
GIFT VOUCHER - How to Use
CONFIGURING Products - How To
Do all products SHIP FREE?
Will my item ship by Letter?
Driver Profiles
Projects
PROJECT "Jaffa" Go Kart
PROJECT Gokart resurrection
PROJECT Timmy's Trikes
JJOOEE's Custom Slider trike!
Custom Trike Build
new bar stool racer
Drift Trike
Drift trike build
SDK 125 gokart build
my go karts
Barstool Racer
125 SHIFTER PROJECT
OLD SCHOOL MINI-BIKE
CRAZY BARSTOOL BUILD
400cc twin engine conversion
the beast
125cc DIY KART
Go-Kart School Challenge
it's a dirty world
cutting the grass
Drift/Fun Overpowered Trike
Triple Terrors
Racing Lawn Mower Project
Dirt track drifter project.
Little Squirt
Project Honda
Dragster BBQ
DIY Dirt / Fun Kart
Awesome DIY Tip
Tricky Trike
twin engined dirt kart
Ipswich Dirt Kart JGR #4
Dirt Kart
bar stool
$49 Flee Market Kart
PROJECT Jasons Dirt Quad Bike
PROJECT - Franks Racing Mower
Guides
CPR RT DIY Kart Assembly
Engine
GUIDE - Pushrod Length Chart
ENCL### CPR Engine FAQ
GX200 Compression Ratio Chart
Tillotson HL-334 Tuning
CPR Flywheel Information
GUIDE - KT100 Carb Settings
Clutches, Gearing & Chains
GT Clutch VS SR Clutch
NORAM GE Spring Replacement
NORAM Cheetah Users Manual
Bully Clutch Setup 3/4"
Bully Clutch Setup 1"
Go Kart Parts List
Axle Kit Secrets
DIY Go Kart Plans
Kart Set-up Explained
Measuring up Clothing
CPR Product Install
BKCC02 Cable Brake System
Health & Fitness
Reviews
Product Reviews
Facebook Reviews
Drift Trike Sleeves TSLR01
ENCL65 new 6.5hp motor
home build
SERVICE
CPR & parts in general
BKDK02 12mm vented brake disc
WPRSDD < WPRRD1 < WHFC1G
BKHC04 Twin piston caliper
Service & Products Review
USBKG Seat Installation Kit
Orders
NPNP1 Numbers and Backgrounds
ENCL35 Lifan 3.5HP Kart Motor
SRAC2G Tie Rods and steering
TCC1234C TORQUE CONVERTER
STACPK stub axle project kit
CMC001 clone camshaft review
ECSC01 Crankshaft review
Testimonials
Facebook Reviews
News
Tools
Brake Bleeding Tool - Single Person System
View detailed images (2)
SICK OF BLEEDING BRAKES THE HARD WAY?
Just want to get them done - properly - without having to ask for help all the time?!
Then have we got an awesome new product for you!
The new CPR Brake Bleeding tool is designed as a single-person system that's simple to use, quick, and performs a flawless bleed leaving your with as-new brakes and the best pedal feel you'll ever get with your hydraulic brake system.
Using a suction system, the tool just needs to be connected up, pumped and fluid added to your master.
Comes with a selection of fittings so that when you're not using it for your kart, you can use it for other brake systems such as the car!
SKU
THBBJ1
Price*
*Note:
including GST
2
3
4
5
6
VIEW ON NEW STORE →
Reviews
Related
$279.00
Need Help?
Gift Certificates
Airboxes (3)
Filters (11)
Rubber necks, Clamps & Acc
3/4" (19.05mm) (17)
5/8" (15.875mm) (4)
25mm (18)
Complete 25mm Axle Kits (7)
30mm (20)
35mm (8)
40mm (101)
40mm Bearings & Carriers (20)
40mm Brake Hubs (14)
40mm Shafts (1)
40mm Sprocket Hubs (5)
40mm Wheel Hubs (10)
Complete Axle Kits (41)
Shaftless Axle Kits (10)
50mm (13)
17mm Front Wheel Bearings (4)
25mm (6)
3-4 inch 19.05mm (2)
30mm (6)
40mm (20)
5-8 inch 15.875mm
50mm Bearings (4)
Engine Bearings (5)
Steering Bearings (9)
Hydraulic (19)
Cable (8)
Accessories & Parts (45)
Chassis Parts
Pedals & Grips (10)
Crash bars and linkages (32)
Cleaners
Cleaners (4)
Clutches
1-INCH Race Clutches (19)
Accessories (22)
Clutches (34)
Accessories (39)
Clutches
Accessories (47)
Clutches (4)
Race GT Range (34)
Accessories (29)
Clutches (10)
Yamaha KT100 (46)
Clutches (4)
Accessories (42)
PRD RK100 Clutches (1)
Torque Converters (24)
Engines (143)
4-Stroke Recreational
2-Stroke Competition & Race
Mikuni Fuel Jets (15)
Crank Case & Bottom End (79)
Pistons & Conrods (133)
KT100 Pistons & Conrods (81)
Exhaust & Mufflers (18)
GX270 GX390 Exhaust Parts (5)
PRD RK100 Exhaust Parts (2)
PRD Heads Valvetrain Cams (4)
Mounts (20)
Throttle Cables (44)
Fuel Tanks (24)
Lids (6)
Breathers (3)
Line & Filters (23)
Hop Up Kits
Mower (Racing) Parts
Plastics & Numbers
Complete Bodywork Kits (6)
Sticker Kits (1)
Nosecones (4)
Side Pods (4)
Nassau and Rear Bars (13)
Number Plates & Numbers (73)
Black (48)
Red (45)
Retro Computing
Sim Cockpits (4)
Sim Motion
Sim PC
Sim Pedals (1)
Sim Shifters
Sim Steering Wheels
VR Accessories (3)
Slider Parts & Kits
35 Pitch Sprockets (58)
Chain Guards (5)
219 Pitch Chains (35)
G-Drive With Joiner Link (12)
GT-GOLD Competition 219P (14)
219 Pitch Sprockets (102)
Rear Axle Gold (38)
35 Pitch Chains (12)
Steering Wheels (9)
Stub Axles & Spindles (34)
Bracket Type (PCR Style) (2)
Project DIY Kits (11)
Shafts & Tie Rods (49)
19mm Shaft Size (1)
20mm Shaft Size (6)
Steering Shafts / Columns (4)
Tie Rod Kits Complete (14)
Tie Rods (27)
Tachos, Laptimers & Gauges
Pressure Guages (2)
Temperature Gauges (15)
Laptimers
Tachos & Speedometers (12)
Trolleys & Stands
Chain Tools and Breakers (6)
Engine Starters
Tools (28)
Grub Screws (7)
Countersunk Washers (52)
Countersunk Washer Packs (26)
Throttle Cable Clamps (11)
Wheel Nuts (12)
Wheel Spacers (22)
Bolts & Nuts (100)
5mm (4)
6mm (43)
8mm (64)
10mm (7)
Springs (19)
Hose Clamps
Wheel, Tyres & Front Hubs
Complete Wheels & Tyres (8)
Front-Hubs (10)
Rims (32)
5" Senior Rims (6)
6" Rims (5)
Complete 5" Rim Sets (6)
Tyres (7)
Shop Soiled
Recently Viewed
Number Pack 2 Digit - 4x Rear & 4x Side Red
Bestsellers
Tyre Pressure Gauge Digital 0.5PSI Resolution with Keychain
Piston Stop Crank Lock Clutch Removal Tool Billet
Chain Breaker for 219 Pitch Chains (CPR Performance) - replacement bolt readily available!
Sprocket Aligner - Laser SNIPER System
Special offers
Sitemap
Products Map
My Shopping Cart
My Shopping Cart
My Account
Sign in
Forgot password?
Free Same-Day Dispatch!
Product Updates via Facebook
We Accept Paypal
Outstanding Service!
Sim Racing
Contact Details
About Us
Condition Meter
Refunds & Returns
Privacy Policy
Driver Profiles
Testimonials
GUIDES - Engine
PROJECTS - Customer Submitted
NEWS & Specials
Sim Racing AMF
Design by
xcartmods.co.uk
