Home :: Chassis Parts :: Bracket for Stub Axle Spindle suit STAC01 Spindle Stub Axle Kits (12mm Hole - does not fit CMBC02 camber adjusters)
Bracket for Stub Axle Spindle suit STAC01 Spindle Stub Axle Kits (*DOES NOT FIT CMBC02 CAMBER ADJUSTER BUSHES)
Weld this bracket to your frame to accept our STAC01 Stub Axle axle kits.  Price is for 1 piece.
40mm W x 65mm H (OD) [55mm H (ID)] x35mm D
Holes are 12mm to suit camber adjusters and reducers.  Use 12mm-8mm reducer pack when using with 8mm kingpins.  2 or 4 Camber Adjusters can also be used in place of 12mm-8mm reducers to provide camber/castor adjustment.
Brand New Bracket for Stub Axle Spindle suit STAC01 Spindle Stub Axle Kits
SKU BRSC01
Price with FREE DELIVERY: $29.95
