Home :: Chassis Parts :: Bracket for Stub Axle Spindle suit STAC01 Spindle Stub Axle Kits (14mm Hole)
Weld this bracket to your frame to accept our STAC01 Stub Axle axle kits.  Price is for 1 piece.
The steel thickness is 6.5mm
The width and height of the mounting surface (back side) is 40mm wide x 50mm high (50mm is also the distance between the inside of the top of the C to the inside of the bottom of the C)
Holes are 14mm to suit camber adjusters and reducers.  Use 14mm-8mm reducer pack when using with 8mm kingpins.  2 or 4 Camber Adjusters can also be used in place of 14mm-8mm reducers to provide camber/castor adjustment.
Brand New Bracket for Stub Axle Spindle suit STAC01 Spindle Stub Axle Kits
SKU BRSC02
