Home :: Brakes & Parts :: Accessories & Parts :: Bracket for Brake Calliper suit CPR BKCH04 & BKCC02 & BKHC02 Brake Kits
Bracket for Brake Calliper suits CPR BKHC04 and BKHC02 Hydraulic Brake Kits and CPR BKCC02 Cable Brake Kits (NOTE WITH BKCC02 holes need to be drilled out to 10mm to suit)
Weld this bracket to your frame to accept our CPR BKHC04 Hydraulic Brake kits.  Price is for 1 piece.
mounting hole spacing centre-centre is 63mm
65mm W x 130mm H x5mm D
SKU BRACB1
Hydraulic Brake Kit (Pro Race Type) including Master & Calliper
Cable Brake Kit GT-RACE (Mechanical Calliper AND Cable)
Hydraulic Brake Kit (Pro Race Type) including Master & Calliper Cable Brake Kit GT-RACE (Mechanical Calliper AND Cable)
$279.90
$119.90
Hydraulic Brake Kit including Master & Calliper
PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 25mm Shaft
Hydraulic Brake Kit including Master & Calliper PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 25mm Shaft
$119.90
$169.90
PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 30mm Shaft (6mm keyway)
PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 40mm Shaft
PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 30mm Shaft (6mm keyway) PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 40mm Shaft
$169.90
$164.90
