THIS PART IS MODULE #5 OF OUR MODULAR GO-KART KIT.
*New Model complete plastics set. Can be used for both 2 stroke and 4 stroke kart applications.
Suits newer model karts with straight (90degree perpendicular) sidepod bars. Can be easily modified to suit older karts.
COMPLETE Kit. Comes with Nosecone, Nassau Panel, and both sidepods.
Nosecone has detachable quick release bracket (pictured) which can be removed and replaced with old-style brackets if required.
Dimensions:
Nosecone - Maximum width (widest part to widest part) = 1050mm, Depth at front (mount section) =108mm, Width of front bar to suit = 300-500mm, Distance from Mount to rear of nosecone where it meets front wheels = Approx 102mm
Sidepods - Length = 600mm, Width(at centre) = 180mm, Height = 200mm, Front cowling adds 95mm width to sidepod just behind front wheel.
Nassau - Height = 700mm (slots into front nosecone), width = 250mm (at mount point near steering wheel).
Dimensions of sidepod picture:
SA - distance from divet to edge of front of sidepod = 70mm
SB - distance from divet to front bolt hole centre = 35mm
SC - bolt hole centre to bolt hole centre = 457mm
SD - rear bolt hole centre to rear of pod = 55mm
SE - Total length of sidepod = 617mm
SF - distance from rear bolt hole centre to centre of divet (cutout for bar) = 75mm
Brand New. *New Model plastic set - Suits 2 stroke and 4 stroke karts. |
