Home :: Engines, Carbs & Parts :: Bearing 6304-C4- Crankshaft suit KT100 (Phenolic Nylon Case Bearing)
52mm Outer Race
20mm Inner
15mm Wide
Nylon non-crack-type high rpm compatible cage
Generally used on both sides of KT100S engines, as well as one side of the KT100J
These are the highest quality crankshaft bearings available for KT100 engines.  PREMIUM QUALITY GERMAN ENGINEERED.
Designed to suit KT100 engines with cranks without sleeves.
SKU BECSKTN
