Home :: Engines, Carbs & Parts :: Bearing 6204-C4- Crankshaft suit KT100J 1x Side (Phenolic Nylon Case Bearing)
47mm Outer Race
20mm Inner
15mm Wide
Nylon non-crack-type high rpm compatible cage
These are the highest quality crankshaft bearings available for KT100 engines.
Generally, they are used on one side of a KT100J with the other side using 6304
Designed to suit KT100 engines with cranks without sleeves.
SKU BECSKTS
