Home :: Engines, Carbs & Parts :: Bare Crank Case & Cylinder BIG BORE SLEEVED KIT 72mm with Flat Top Piston and Rings and Pin and Circlips suit GX200/160 Clone including CPR engines
Complete Bare Case and Cylilnder.
There is no replacement for displacement!  More capacity means more power AND MORE TORQUE!   Treat your GX200 engine to a power boost you'll really feel!
GENUINE TILLOTSON FACTORY CAST 72mm PROFESSIONAL BLOCK
CAST IRON SLEEVE
Professionally designed and manufactured to exacting standards.
Re-inforced case design.
Includes matched 72mm flat top piston, rings, gudgeon / wrist / piston pin and circlip pair.
Designed to replace GX200 and clone blocks - re-use your existing components and build a big block GX200 easily - in stock ready to ship immediately!  NO WAITING!
Suits most standard clone side covers - interchanges with all CPR 200cc race engines and our ST1 engine.  If you aren't sure if your side cover plate will fit, you can buy one by clicking the 'related items' section below.
THE ULTIMATE GX200 UPGRADE!
Serious about powering up your GX200 or clone?
So are we! That’s why our 72mm kits are built by the best, ready to bolt straight on to your existing 200cc GX200 or clone!
COMPLETE MATCHED KIT
Built with extreme care, matched piston, ring, pin and circlips come with the kit to ensure perfect and exacting builds that produce maximum power reliably.
FLAT TOP PISTON INCLUDED
You won’t need anything else because we’ve even included a quality flat top 72mm piston in the kit!
SIDE COVERS AVAILABLE
While our case fits most existing side covers including our ST1 model, we carry spares in case you need one.
IN STOCK AND READY TO SHIP - NO MORE WAITING!
Going fast should never mean waiting around for things to happen. That’s why we carry our kits in stock ready to ship the SAME DAY using our FAST dispatch service - so if you’ve paid before the cut-off time on a CPR working day you’ll be tracking it as it makes it’s way to your delivery address, that day!
SKU ECC72K
Price with FREE DELIVERY: $449.00
