NEW KIT IS NOW SUPPLIED WITH NEW-STYLE PLASTICS - (RETRO STYLE SIDEPODS AS PICTURED) THIS KIT IS SUPPLIED WITHOUT CHASSIS & BRACKETRY - ALL FITTINGS STILL INCLUDED Our new BTR DIY Kit (Complete) brings a new dimension of fun and excitement to go karting. Whether you're just starting out in karting, or you're looking at a cost effective alternative, our DIY kits are easy to assemble and offer quality CPR components as well as an assembly manual. Building a CPR go kart is fun for the whole family, and after it's built, well it's still fun for the whole family! This kit is a full kart including the engine. Everthing is there including your choice of gearing and chain. And if you want to go even quicker, you can choose between our 3 high performance engines for an additional fee. Supplied with silver anodised parts and silver zinc plated high tensile bolts, washers and nuts. It can be upgraded to black hex socket head and countersunk head high tensile bolts with our anodised colour system for an additional $50. Simply select your colour from the options in the drop down menu. This version of the kit includes our popluar new Race Sticker Kit. Here is a run down of the main components. Of course, all bolts, linkages etc are included to complete the kart. 2. Pedals, bolts and pedal return springs (supplied but not pictured) 3. Steering Assembly and all nuts and bolts/spacers etc to fit. 4. Stub Axles and all nuts and bolts/spacers etc to fit. 5. Brakes and bolts to fix to chassis 6. Brake Rod, pins and split pins 7. Complete rear axle assembly includes two bearings all nuts and bolts including disc. 8. Complete set of front and rear wheels with tyres 9. modern style nosecone and nassau plastics with fittings but without bars 10. Seat 11. Complete bolt kit including springs, fittings, spacers, etc etc 12. Assembly Guide 13. #35 Clutch, Chain and Sprocket 14. 6.5hp CPR Performance Engine (Upgradable - choose from our high performance options) **** PLASTIC FRONT MOUNTED FUEL TANK NOT INCLUDED WITH BASE 6.5hp CONFIGURATION **** New. Brand New (DIY ASSEMBLY KIT) |
| SKU | BTCDIY_ER2_NOCHASSIS | |
| Base product price: |
$9999.00
including GST 10% |
